Take the wheels off, remove inner ach panel (unsure of the real name) they just pull out from the flexible plugs, undo two torx screws for fogs and disconnect, then you'll see the surrounds are held in by flat pins. Push these down with a flat headed screwdriver while pushing the surround outwards and hey presto!!
I changed mine the other day, small flat bed screwdriver, and a rag to protect the paint, u will see a gap around the fog surround where it meets the bumper, i started in top corner where it goes in the side, unclip that one and just go round, 5 clips in all, 2 on bottom, 2 on top and one in the top corner.
will go geta right angle pick from work as this will get behind the cover without levering on the paint just didnt wanna prise it out if it was screwed in from behind
