Foggy windows
ripp
  182 FFAT
Hi everyone,
So this time of the year is foggy windows back again.
Did a search on this subject but looks like I covered most common issues so far:
AC works spot on, changed some seals couple of days ago, did a refill and leak test and it's fine.
Pollen filter is nice and clean and dry
I can't find any moisture on the carpets or any other part of the interior.
For the last couple of days the car is parked in an underground parking lot so it's safe from negative temperatures overnight, but after I drive for a couple of minutes in the morning with the AC on it still starting to mist slightly and it really bugs me.
Prior to having the AC system checked I suspected that was the issue as there were only about 250g of refrigerant left in it so I had high expectations after I sorted it but looks like it's another hidden issue 😔
Any ideas?
P.S: my other vehicle that is parked in the exact same spot overnight doesn't mist one bit, even if I sometimes forget to turn the AC on.
