Foglight bulb fitting help
Car  RB Clio 182
Hi, ive just received my foglight bulbs, whats the easiest way to access them to change them, thanks for any help.
Tom.
I changed my passenger side one last weekend . I realised you need to remove the bottom trim to access the light but ive just moved house so all my tools are boxed.
But theres just enough room to doit was a little difficult and scratched my hand but only a few mins work and it was in. So i bet you could fiddle the drivers side in also!
Do you mean the black trim behind the bumper mate?
So you didnt need to take the bumper off etc :)
Yep i managed it with everything in place! I only did the passenger side so i carnt coment on drivers.
I just pulled the passengers side up the kerb for more room underneath its fiddly but you can get your hand in and twist the old bulb out and twist the new one in.
As you face the fog light there is a gap in the black plastic trim just to the left and you should be able to go in there . Let me no if you manage it and if the drivers side is easy to access cause now i have to diffrent shade bulbs i want to change the drivers old yellow one
Brilliant mate i get you now as i had a quick look earlier.
Ill go fit them now and let you know about the drivers side :)
Thanks again for the help, Tom.
Hi again mate, all done! I jacked the car up at the drivers side which lifted the passanger side up enough too.
I did the passanger 1st like you said, its tight and fiddly but managed it in the end.
The drivers side is a tad different, you dont go throught the side like on the passanger side, ull have to jack it up and have a look under, ull see where the backing splits, i just pulled it down and got it from underneath, its just as simple as the passanger side tbh mate, only difference is you go in from underneath and not the side, hope this helps :)
Tom.
Cheers not bad at all. Will grab another bulb at the weekend. Its nice when you dont have to remove anything!
