Followers
Barron
  RS4,Exige,R5,182
spot on mate, think i used to wrong terminology but you put the part number for the rocker up which is what i need i think.
the bit that connects the lifter to the valve, am i right?
carl
part 9?
There's another number listed: 82 00 115 605
I'd check with your dealer as to which is correct
Barron
  RS4,Exige,R5,182
any chance i could grab part numbers for 1-10?
appreciated :)
carl
1. 77 00 115 267 ARBRE CAME ADMISS
2. 77 00 107 555 CAM FOLLOWER
3. 77 00 873 652 COLLET
4. 77 00 114 978 VALVE SPRING
5. 77 00 114 112 CUP S/ABS
6. 77 01 471 279 VALVES X8 INLET
7. 82 00 032 853
8. 77 01 473 101 VALVE SET X8 or 77 01 472 426 VALVES EX SET C2
9. 77 00 107 556 VALVE ROCKER
10. 77 00 108 211 PLUG
