we did approx 240 on a stock bottom end, bar the rods being balanced, the entire assembly balanced, Wossner high comps, a head with a fair bit of work (currently for sale!) Schrick cams, and a bit of tinkering with the compression (higher), big injectors and a proper map
first time round the engine dyno'd (on an engine dyno) at 225bhp, then it s**t itself due to a problem with the honing
second build it was bang on, we changed to Total Seal rings, f**ked about with the compression a bit, and it pulled 205 @ wheels which going off the dyno cell V RR comparisons was approx 240
