Forged rods...
Car  C63 AMG, F430 & 172
I'm changing the pistons in my engine to high comp, but I'm still debaiting weather or not to fit forged rods!
I plan to fit ARP bolts anyway on the big ends! Will be reving to 8000rpm.
Worth the outlay (new there £450) ? Or will the OEM hold it?
Cheers!
peice of mind tells you that spending £450 on some rods or £1000-£1500 on a new engine when it go bang at 8k, is the sensible thing to do...
do it once, and do it right....
it seems a lot now, payin £450, for somehting that youve already got and chances are will be ok. but its that part of you that wishes you shouldve gone for the forged rods...
while its apart you may aswell...bullet proof engine almost.
at least you know that if you up the anti later on with more mods the engine will be safe
I would dude
It'll not limit you if you ever decide to go further still, either
Going by your last effort, you don't do things by halves ;)
Is 8K the rev limit or the point of peak power i.e. will you be going beyond 8K RPM often?
Unless the cams you'll be using require circa 8000RPM I'd just stick the limit at 7800RPM at which standard rods (and standard valvetrain) are proven and tested.
M
Well no, the cams are 428s
So I think peak power is around 7700-7800? no?
I just put 8k as a max! If the oem rods (with ARP big end bolts) will hold at that then thats good news..
I was going to change to 422's but i just cant be arsed spending the 700quid.. when the 428s are not that far off!
thoughts?
428's are fine. They will make power at 8000RPM but to be honest they are just over the top at 7800RPM IME with a fairly decent flat end to the power curve between 7450'ish and 7700rpm.
That 7800RPM isn't going to be sustained anyway as you aren't going to slam it into the rev limiter at the end of every gear so to be honest with you I'd save your money. Get a set of standard rods checked for roundness and crack tested, use good quality tri-metal big end bearings and ARP fasteners. That should see you fine for 7800RPM with reliability. It's worth noting a lot of standard cars with remaps are running around with 7800RPM limiters!
Are you still planning to raise the CR? How much power are you after?
M
Stock rods are fine, just fit ARP bolts and you're done (balance the rods though)
we ran stock rods on the monster but with a 7500rpm rev limit, 205bhp@wheels :D
rasing CR to 12.6:1 boring to 83.0mm.
I want to hit 240 tbh, the head will get a full gas flow, getting the crank and fly balenced/lightend etc.
What do I need to hit 240?
422's tbh
I think I can make it there without the need for 422's
428s have good lift! plus the head will awesome! (im good with a nail file:o)
Depends on the rolling road. ;-)
The rods are strong enough with sub 8K limits for that. Paul has been running 296bhp on them for months now.
With a well done cylinder head, 428's, high comp pistons and a healthy engine I'd expect to see 230bhp'ish. The other 10bhp would come from an extra 500rpm and some suitable cam profiles, but that involves new cams and steel rods as 8K is the absolute limit for standard rods IME if you want to ensure reliaiblity.
Don't go setting a power figure and chasing it - thats what marketing people make development engineers do ;-) Put a sensible package together for your budget that'll be reliaible and easy to maintain and build that. It'll make decent power either way and theres no point massively compromising engine life for the sake of 15bhp.
M
we did approx 240 on a stock bottom end, bar the rods being balanced, the entire assembly balanced, Wossner high comps, a head with a fair bit of work (currently for sale!) Schrick cams, and a bit of tinkering with the compression (higher), big injectors and a proper map
first time round the engine dyno'd (on an engine dyno) at 225bhp, then it s**t itself due to a problem with the honing
second build it was bang on, we changed to Total Seal rings, f**ked about with the compression a bit, and it pulled 205 @ wheels which going off the dyno cell V RR comparisons was approx 240
428's
forged pistons
standard rods + ARP
uprated bottom end bearings
full balanced bottom end
flowed head
lightened flywheel
standard valves + springs?
decat and SS im supposing? :P
think that would make a proven 225-235 on pauls RR
428's
forged pistons
standard rods + ARP
flowed head
lightened flywheel
Ive got
sports cat, which will be a de-cat
182 manifold (not sure if this is what i want tbh, it may be up for sale)
Standard valves and springs
Lightend flywheel
Got up rated bearings
got pistons
got ARPs
the head is a half arsed job, it needs work
the map is s**t lol.
Ive got
Lightend flywheel
got pistons
got ARPs
with decat and that spec (say a standard head) i would suspect 215-225
not sure how well 182 manifolds are with power figures on itbs
no idea its its phs1 or 2, it cost some ridiculous amount originally, was done by one of the prodrive engine guys
