front and rear mk 1 bumpers
stu
  Clio Mk 1
simple question really can anyone tell me where the fixing points are and what tools i need to remove them?
cheers
  mk1 RT
you have one behind each wheel under the arch liner
on the rear theres 4 iirc from under it then it should slide out
the front theres one behind the numberplate and mine had 2 from under it
on mine they were all 10mm nuts appart from the one behind the no plate that was a 13mm
a basic socket set will do fine as long as you have an extension bar
and a screwdriver for the no plate
