where the bumper ends at each side behind the wheel arches should be a 13mm bolt, undo at each side, then below and the bottom it sould be attached with 2 torx screws, depending on which model uve got, can be attached at top aswell
Dont forget the metal clips that are next to the 13mm bolts, also, there are two plastic fasteners underneath the bonnet and two bolts under the car as well.
