Alrite peeps i have 1.2 16v clio 2001 model mk2 model before face life, and my standard dampers at front have sagged so need sum advise or ideas on wat deals are out there for just front dampers. As currently i have 60mm springs all round. Anyone no any gd deals
well i got two sets 60mm springs aswell so that dont matter but my standard dampers ro fooked bouncy as anyting need sum ideas on wat uprated dampers to get
You'll usuauly find dampers and springs come as better value as a set you can get sports dampers and spring sfor about £200~250 though in a few different spec APEX etc.
Theyre 99.9% likly to be he 58mm ones.
Only way to be sure is if you measure them. Its the distance between the two bolts which bolt the strut to the hub. If you stick th wheel on full lock you can see the bolts.
