Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I've just replaced my front lambda sensor with a brand new one and the codes (sensor circuit and heater circuit) have reappeared after about 10 miles. Anyone know what this could be?
Quick update on this - just fitted the Bosch sensor from the link above which was £47 inc postage... and the issue is solved. MPG shot up from 28 before to 39 (?!) on the motorway, a pretty massive improvement...the non-genuine ones are complete rubbish!
At the same time I fitted a drivers side driveshaft from J & R which was a massive bargain at £50! It even came with both cup and non cup ABS rings, and proper plastic boots.
Shaft is fitted and fits/works perfectly, I only had to switch the ABS rings over since mine is cup packed.
Initially I thought the shaft was too shot because the threads didn't show through the hub, but refitted it and all was correct.
The inner joint has to be slightly expanded for the hub nut to be bolted on which I think was the problem
