Front washer and rear wash/wipe
  PH2 Flamer
My front washers have gradually got worse, and now after 30 mins of unblocking the eyes in the jets. Still no better. Barely come out of them. And only 3 of the jet eyes actually squirt.
So thought I'd check the rear. And nothing. The rear wiper was working. But today it isn't? Any ideas?
When I do try and do the rear wash/wipe the fronts squirt a bit and front wipers go off. Weird!!
When I activate the front/rear washers the motor does make a noise. So am guessing that's ok? Also I've never seen the headlamp washers go. But tbh I'm not that sure if I've used them? Will they always go off if lights are on?
  Clio 182 Cup
Sound very similar to the problem I had with mine, the motor spins but nothing comes out. What you need to do is take the motor out of the water bottle and remove the pipe work on the end where the feed for the front and rear go into. carefully take this apart and you will find a rubber tube inside. Take the tube out and then with a sharp knife cut about 2mm off each end. re-assemble and all should work.
