stu8v said:They cause bore wash and are a bodge. The only correct way is a remap. Anyone that tells you different doesn't understand!
u33db said:I disagree.
0.5bar or thereabout isn't going to damage anything, it will however make an improvement...as i said the map on the cars is mega lean top end so you need it richer.
I do agree a remap would help control things better but if the cars physical components cant supply the fuel needed then your pissing in the wind! Get the better pump and regulator then think about remapping IF you need it.
stu8v said:Even then you could be beyond the working range of the injectors, use the correctly mapped and matched injectors.
