Fuel filler flap
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
Bolts through the front held in situe by the plastic. Nuts in the rear in the arch which get cakes in s**t , and become a pig to free off
GrahamS
  335d
if you want just the flap off instead of the mechanism you can remove it from the outside. Open the flap then then pull it outwards from the far, use a screwdriver to pop the clip off the mounting. You'll see what I mean when you pull it out.
