Fuel Filter location
  Clio 172 Phase 2
Hi
Got a service pack for my clio, fitted everything apart from the fuel filter, I haven't got a clue where the old one is so I can replace it. As far as I can see its not in the engine bay, so im guessing theres and inspection panel somewhere. Can anyone help me out?
Renault Clio 1.2 16V Expression 2002
Gaz :D
maynard
  ph2 172 track car
in the fuel lines near the tank, or possibly actually in the tank itself?
  Clio 172 Phase 2
im thinking its probably around there somehere, do you know how is most easy to access it?
maynard
  ph2 172 track car
just had a quick look at the dialogys, seems to be at the front of the fuel tank, possibly a strap holding it to the side of it?
i imagine you would clamp the fuel lines, pop the filter out, new one in, and reconnect lines. something along them lines - someone will be along soon enough to confirm!
oh, and you may also need to disconnect the fuel pump relay/fuse before you disconnect the filter otherwise you'll find fuel will come out of the lines!
Alastair.
  986'S 172ph1+182FF
its in the tank, part of the fuel sender, doesnt need to be changed really until 140k
  Clio 172 Phase 2
Thanks for that maynard, ive looked around there and cant see anything so im guessing its in the tank.
I thought that it probably didnt need to be changed at the moment, but I dug out an invoice that came with the log book when I brought it, and it says it had one done when it had a cambelt change (55k miles). Its now on 113,000 so I thought i'd change the lot. Ill have a proper look in a bit.
  Mk5 golf gti
its inside the tank on the phase 2 gazza :)
if it was changed at 55 k it wont need changing for a while as they are rareley replaced on cambelt
the ones inside the tank anyway
thats if it was changed ;) lol
  Lionel Richie
doubt it was changed, a new sender unit is cira £200+ from memory, mine lasted 9years before it packed up
