Fuse help!!
  Arctic 182 & PB 172
Two problems...please help!
My headlights arent working...i think something is missing. My sidelights and main beams still work as the same light but where do i find and replace the relay or fuse for headlights?
Also my centre console display with temp and time only comes on when i turn the lights on and that went out the same time as my stereo stopped working...what do i do there?
Thanks in advance!
  Megane dci 130
For the first fault, does the green tell tale light come on the dash when you turn the lights on? If it does your problem will more than likely be both bulbs,mif it does not, the fault will be further back (fuse or switch)
The second problem will be a fuse, check them all.
