Gear stick cover
Car  172 cup
Are these easy to remove and re fit? Mines broke so need to purchase a new one and replace. Anyone done this?
It's broken at the bottom so it's flapping off, the plastic rim bit round the bottom has snapped somehow
Could you get a picture my tabs broke off the bottom and I put some
Self tappin screws in the bottom and worked perfect tbh they just brake again anyway so best to fix them stronger then they come new haha
if by gear stick cover, you mean the 'gaiter' then its around £10 from renault.
i did mine the other month, it comes as a pack with the cover and plastic bit.
just have to turn yours inside out, cut the cable tie and put the new one over and cable tie that and clip the plastic frame in.
job done.
