In 1st gear when you gently accelerate and then back off you obviously get some engine/gearbox shift on the mounts back and forth.
My Cup has started to make a click on forward and backwards movement of the box/engine, its quite loud and metallic sounding as if the gear stick is hitting the front and rear of the gearbox tunnel and seems to be coming from somewhere down by the gear stick.
Anyone have any ideas? Linkage issue?
