gearbox oil
  ph1 black 172
hi all,
changing a driveshaft on saturday, thought i would do the gearbox oil at the same time.
problem is i cant get hold of 75w80, everywhere sells 75w90.
can 75w90 be used?
any help appreciated.
  a thirsty one
opie oils do mate, do you have a german swedish and french shop nearby they should be able to as well.
EPX is pretty cheap and chearfull but it will do fine :)
You can use 75w-90 but it can lead to a baulky shift when hot due to the higher viscosity.
Guy
  ph1 black 172
cheers all.
well i fitted the driveshaft and i didnt lose a drop of oil, the driveshaft doesn't go into the diff on my 172 it sits on a stud that comes out past the gearbox oil seal.
just gonna change it with 75w80 anyway
