Gearstick play
Radugns
  Clio 172 ph2
Hi,
I have an annoying play on the gear stick and I would like to solve the problem. I've checked under the car on linkage bushes, but everything is fine and the only play is in the gear stick housing, that rubber bush.
How can I solve this problem in a better way than replace with new Ren parts?
Thanks,
Radu
  Clio Sport 182
there's a guy on here that should be able to sort you out he's an expert on the gearstick side of things and makes custom parts, and BETTER than genuine bushes. goes by the name on @Yanoo
Radugns
  Clio 172 ph2
Does anyone know if the gearstick itself in the housing from another clio, like 1.6, 16v, fits the 172?
