Gearstick question
Car  clio sport 172
I have a question regarding the gearstick movement. the stick has little movement (left-right) in every gear. no movement forward-backward when standing or on full throtle. the gears change are fine, no crunching or any other noises. i changed the gearbox dogbone mount (orig. Renault) and the oil (tranself 75w80) and the new clutch set. I've change the seal so no oil leaking fom the box either.
As i said no problem with any gear when changing them, just this little movement when in gear (similar to the movement when the car is in neutral).
The car has 142.000 km
Is this OK or?
