Glass polish
Joe#
Does glass polish work as a rain repellent?
And does anybody recommend 'Dodo Juice Supernatural Glass Polish' or any others on the market?
  Golf GT & A4 Avant
I won't use RainX again as it would often smear and didn't really work that well for very long.
I'd also recommend the GTechniq G3, have been using it a while on mine and the GF's car with good results at 30mph. Their sealant C2 neat works well on glass as well as bodywork, and works from approx 45mph
Coby.
  XC60-R.......V40-R
Never thought of using it on the shower and mirrors...Cracking idea Jamie.
Joe#
RainX went on my shower glass and mirrors only.
Great idea :)
What sort of procedure should I carry out whist doing the windows. It's never something I've ever thought about really?
Oh and I'll check out the GTechniq stuff out now cheers :)
  Golf GT & A4 Avant
I prepped my windows with a simple wash, glass cleaner, clayed, glass cleaner again then applied G3.
I've had G3 on 1 of the panels on my shower screen for a month now, prepped as above, as our area has terribly hard water and is still working well
Wash with pH neutral. Clay. Wash again and dry. Polish with glass polish. IPA wipe down to remove oils. Then your chosen sealant. The IPA wipe down could mean the difference between 10,000 miles and 30,000.
Having said that, the GTechniq system seems to work very well together. Worth getting the polish and sealant together, and forget the IPA if you go down that route.
Likewise Dave. The window on our shower (glass panel for an open shower, not bath, so right next to the shower head) was opaque with lime scale (Clapham, so hard water like you). Lime scale remover (with gloves on!) then process above and it still beads. Just needs a rinse over after use with the cheapo watering can from Tescos.
That last part is for Roy.
Joe#
Thanks for that. I'll try it out this weekend :)
  M135i
I've never had a problem with RainX on my side and rear windows. Put it on with a bit of kitchen roll, leave it for 10-15 mins then biff off with a micro fiber. Lasts about 6 months with regular cleaning with megs glass cleaner concentrate or my new found love, Autosmart 20:20.
  Clio 197
Collinite 845 on my windscreen, got away with hardly using my wipers in the rain we had enroute to FCS :)
  182
dodo juice supernatural glass sealent kit, worked brilliantly on my old astra need to get some on the clio soon
