Good vibrations
Car  172 Phase II
Well maybe not so good but a vibration nonetheless. And it's a very specific one.
In 2nd gear, at around 4k rpm I hear a rattle/vibration. This is just a moment and only occurs when pulling hard. When going slow and passing 4k I don't hear it.
I also never hear it in any other gear. And seems to be coming from the front.
The only that changed recently is that I have a sportscat now.
Anyone an idea as to what it can be?
nah......4k rpm is the heat shield.
In mine, a phase 2 172, its the wire from the downstream lambda sensor just tickling the heatshield at the cat
2 tie wraps in a figure of 8 keeps it at bay dude
J
Oh man! That's exactly what I didn't do. Just left the wire hanging, seeing as it didn't interfere with anything and I was fed up fitting the cat.
Hope that that will solve it!
You did nothing wrong mate, there is no mount for it that i saw apart from the actual connection
When i look at mine which was brand new, it was......well....fairly pert :) and sat about 1cm from the heat shield. I can only assume at 4k its flapping like a fool, maybe the resonant frequency.
Also, if you have a noisy pipe, it might just be the noise of the exhaust causing the heat shield to resonate. That would be bad luck tbh
J
Well I saw how it was before, secured with two tie wraps in those little holes in the heat shield. I just didn't put it back that way.
