Hi guys,
Ive got a W reg clio 172.
1) what is the sensor located on the top right hand side of the engine (tucked underneath the engine hood)? Its grey, about two inches long x 1cm wide x 1cm deep, unplugs from the engine. Once unplugged, it comes apart - forming two parts approx 1inch x 1cm x 1cm each, with one part still attached to the lead, the other part free. Research so far indicates its some kind of manifold pressure sensor, but im not sure. Ive got some photos of it but not sure how or if I can upload them onto this thread.
(im not very mechanically minded, so some explanation of what it does would be really useful too)
2) if faulty, could it be the cause of the engine turning over but not catching?
3) is it easy to replace? approx cost of a replacement part?
Basically, my engines not been starting on a few occasions over the past 4 or 5 months (turns over, doesnt catch as in point 2 above). Usually, after tweaking the grey sensor it will start beautifully. Today nothing is happening, tweaking makes no difference, ive tried holding it firmly in place, but car just isnt starting. It appears to be dead.
I took it into Renault ages ago when the problem first arose, and they said that the sensor looked fine, and its normal for it to feel a little loose. Electronics test came back fine - they found nothing wrong with the car that would cause it not to start (typical).
Brad
Brad
