2003 Clio 172
Hey team,
Ok, i posted about this before as part of an essay style post but it was lost amid other posts. Rather than bumping that i thought i'd give it a thread of its own.
Firstly, car has been missing terribly of late and after a quick pull down the other night, i noted loads of flash over marks on one of the plugs, so i cleaned it down, made sure the plug lead was clean and dry and reassembled and that seems to be much better, no more misfires (but i have also lost the lovely bangs that used to happen, fark!)
Anyhoo....on to my main gripe and probably quite unrelated to the above.
When driving.....in ANY gear, if i labour the engine (i.e. low rpm, high load) for example, putting it into 3rd at low speed.....i can hear what i can only describe as a grumbling or grinding noise that seems to be from the driver side (belt side, i know ) of the engine.
No i don't drive like this all the time.....i am just trying to describe the scenario that causes it.
It can be heard in all of the gears....i.e....starting off in first.
The odd thing is that it disappears at the same rpm in every gear.....somewhere between 1 and 2k rpm. Id say around 15/1600.
I had read somewhere that the dephaser engages at 16 or 1800 rpm and was wondering, could this noise be coming from that? Perhaps its on its way out? Dephaser makes no noise at idle. none.
Another thought was that it might be coming from one or some of the pulleys or tensioners in the belt setup? Belt was done about 25K ago.....dephaser was not replaced.
Pinking? Could this be pinking? Its not the classic noise that i know.....
Finally, could this be the waterpump? Would be odd that it would disappear at that particular RPM.
Would really appreciate any and all thoughts
J
J
