Unto the 2 bolt that hold the pad carrier in(iirc 15mm) pull the bads out, then WIND the piston back in, insert new pads into the carrier, place the carrier back on, do the bolts upo nice and tight, then unhook the hand brake cables, make sure the lever is right back, start engine, pump brake pedal, then put the hand brake cables back on, and it will have adjusted the hand brake too.
