Guide to Fitting Apex springs please
Rear, undo the 2 18mm bolts on the bottom of the shocks, jack up, replace springs, done
Front loosen 21mm top caps, jack up + remove wheels, undo 2 x 21mm bottom strut bolts, remove strut, undo 17mm top retaining nut NO NEED FOR SPRING COMPRESSORS!! wack on new spring job done”
Taken from Fred in an old thread. Fitted some sportlines a few weeks ago & it’s pretty straightforward although I didn’t find it quite that easy.
