GUTTED FRONT WING HELP PLEASE
Car  172 rs
need to know where the cheapest place is to get a drivers side front wing is please for a clio 172 as my car was involved in a hit a run in morrisons carpark today (w*****s) are all clio 182 and 172 parts the same or will another model wing fit
all help much appreciated cheers
try eby or ask on here in the 'wanted' section
also renault charge around £50 for a wing (unpainted) iirc
You need a 172 or 182 wing as they are different from the non-RS Clio's.
As stated though they are quite cheap from Renault (unpainted).
yeah, 172 and 182 wings are the same part and you could even find someone breaking a 182/172 and use that wing. it'll probably be cheaper and you might even find one in the colour you're looking for :)
Ah you'll be right then, the most common colour produced :)
Just a point to note, if you're buying secondhand the silver on a 182 will be different.
