hard drive problem sata i and ii
Car  ex Clio 172 owner :(
Will a sata ii hard drive (3gbps) work on a sata i board (1.5gbps)?
Having a bit of trouble with an install. My mate says to use the jumper on the sata ii hard drive but there isn't one.
Cheers.
Yeah you can. Most SATA II drives have a tiny jumper on there. I thought by default they ran in SATA 1 mode until you removed the jumper. Most hard drives we get in are like this
^^ yeah back of the hard drive there should be a load of pins which limit it to 1.5gbps when a jumper is placed over 2 of them - rtfm seeing as you dont actually have any pins.
Check your bios too, see if you can change the speed.
So -
RTFM of your motherboard
RTFM of your hard drive
and check your bios, try resetting it while your at it as a last resort.
Cheers.
Having to rma the motherboard as the intended hard drive is sata ii with no jumper.
Even a mates sata i drive doesn't work.
Why I volunteer to build pcs I know not.
