Harness lapstrap mounting point
  My trusty lil 182 :)
Quick release or bolt in? Are you using after market seats/subframes?
I am running cobra subframes which have a harness mounting point for a bolt or eyebolt. Mine are quick release so eye boly on the subframe and then clipped the door side to the standard seat belt bar. If they were bolt in I would just have bolted in to the seat belt bar bolt.
If you are using standard seats, the door side bit applies but the mid car mount would be a bit more tricky. I think you would need to drill for an eyebolt and put a stress plate behind for quick release harnesses. Not sure for bolt in. There may be a bolt for the standard seat belt 'clicker bit' (!) or maybe just lift the seat and use one of the standard seat mounting points?
