Hazard lights + auto lock
Car  Clio mk2 ph2 1.6
After fitting a new hu neither of the buttons work. Is it a fuse or have I pulled something out when installing it. Sorry if it's a stupid question but i'm not the most technically minded person so don't want to go fiddling about with wires lol. Thankyou
More than likely that you've pulled both of the plugs off the back of the switches as you've pushed in the HU.
Best thing to do is remove the HU, then unclip that switch panel above.
Then put the HU back in before replacing the switch panel. That way you can make sure the wiring doesn't get snagged when you push the HU in.
right managed to fix it, the wires had just come out, now i cant get the hu to work lol all connections fine, fuse fine, has power to it cause disk will eject but wont show anything
