Hazard switch
  Megane 250
So I've just been out and was stuck in a bit of traffic, someone let me into there lanes so flashed the hazards to say cheers...
Now they won't stop flashing unless I hold the switch in, I've pressed the switch numerous times and still nothing, I've currently got a piece of paper wedged in there to hold it in place.
What could it be?
  182
sounds like u need a switch
From memory when opened up u will see a small chanel which either a piece of plastic or metal runs up, this chanel has probably worn so it cant lock in.
Marc.
These are unreliable as hell on Clios, I've had to replace mine twice in 5 years, and I don't often use my hazards. Cost about £15-ish for a replacement from eBay, fascia clips out easily enough.
DrR
  VW Golf GTD
How can a switched that's used so little be so bad!
