Head gasket sealer
Thanks for your helpful comments.
I am refering to sealers such as; Red Hermatite. - not sure about the spelling.
i used the RED gasket stuff on my exhaust but personally wouldnt use it on the head as if u miss a bit of it doesnt set ull av to take the head off again etc
jus use a normal or uprated gasket
  172 Cup
do you need to use sealer on the rocker cover as well as a gasget as they are prone to leaking?
Paul
  172 cup,s2 rs turbo
you need to seal the cam carrier section though.you will see which bit i mean when you strip it down.
