Headlight adjustment?
Car  PH2 172
Hi,
I had my headlights out the other day to change the bulbs over, and now the N/S one seems to be dazzling.
Is there any way to adjust the beam on the Xenon units?
It has auto-adjusters... maybe one of them has gone? You can do it manually bt screwing a little white allen-key fitting thingy on top of the rear of the unit.
I thought it had auto adjusters! Maybe it has gone? I remember seeing the white screw at the top, is it accessible whilst the headlight is in situ?
Also is there a specific way to check when it's set correctly?
You can turn the allen key bit while the headlamp is in situ. The only way to check if it's correct is to take it to any MOT testing station, they shouldn't charge anything/much!
cheers for this thread lol
I was trying to find out the other day how to adjust my headlights when i go on holiday with alot of suit cases lol
