I have water on the inside of the drivers headlight.
Am i fucked for fixing this or is there an actual way to rid it, absolutly fuming when i seen one of them misted up to hell.
Take the cap off the headlight every time you park up. It also helps if you can take all the bulb holders out for a few hours so that air can circulate out of the units. The water inside evaporates pretty quickly because it's warmer inside the headlight, and the vapour escapes with the circulated air.
I had exactly the same thing happen soon after I got the car and this sorted it.
You could just leave the rubber caps off for a few days but you'll risk getting s**t in there (a moth in my case). I'd just take them off when the car's stood still. Take the bulb holders off too to get as much air circulating through there as possible.
In that case, take the unit off the car, take off the rubber seal, then use a hair dryer to heat the offending areas where water has accumulated. This will evaporate it and then use a fan to move the air (now moist air) around and out of the rear holes.
