Clio 182
Hi All, My 182 failed its MOT on a couple of things and one was the headlight washers. I had bought new washer units before as I knew they were leaking and draining the tank, I hadn't fitted them as unaware it would fail for this. Anyway once I changed them I realised they still didn't work and found the pump wasn't running. I presumed this was the problem and ordered a new one but once fitted it still didn't run. I should have checked by swapping with the other pump but never mind. I also should have checked the fuse prior to all this but when I checked, it's ok. Im lost now! is it the Wiper stalk in the car? The windscreen front and rear work fine.
Thanks in advance for any help as Retest is on Tuesday.
Gavin.
Gavin.
