Headlight washers ??
  Monaco 172 Ph2
Where do these get blocked up ??
Well im assuming they are as i can here the washer motor attempting to squirt lol
Any advice or pics on where to look would be appreciated,
Was just thinking of blanking them off but wouldnt i need to cut power to the washer motor for the lights ??
Thanks.
I had similar problem. I found on mine if when I removed the washer pumps from the bottle to check, inside each of the pumps there is was a small rubber cylinder, the ones on mine had swollen up so I just shaved a little bit off either end and rebuilt. Has worked fine since. On mine only the rear wasn't working but I did the other pump at same time as its a pain to get at you have to take the wiper arm off to remove the trim. Might not be same fault but cheap fix to try first.
