headunit probs, help...
Nafoff
i have a rotating kenwood headunit, the other day when i started the car the front didnt twist to work but only to take the headunit out.
i thought that power must still be going to the headunit for it to twist so cant figure the problem
any ideas.
try pressing the reset button on the head unit, but ur gonna need the mask key to switch it all back on again. If that dont work unplug the power from the back by taking the headunit out just simple take out the fuse for the interior lights and headunit in the fuse box on the front passger side and put the fuses back in which should also reset the headunit. hope this helps mate. remember doing any of the following should reset the head unit and your gona need your mask key to turn it all back on if your headunit has mask protection.
Nafoff
yep tried taking the power lead out and the fuse but no joy, rung a company called sextons they said they would send it off and it sounds like a specific wire which should cost bout £75...
£75 for a tiny wire.
