Headunit probs
  Impreza STI v5
Just got a new JVC KD-SH701 and it's not holding the memory, switch power off and take the keys out then turn it on again and all my settings are lost any ideas
  Ford Focus ST2
sounds like you have the switch 12dc and the permanent 12dc around the wrong way
I am not sure of the colour wire used with the JVC head unit but i know the sony one is yellow and red
have a look and swap them over, if you sent me a picture of the wiring loom and the back of the head unit i well tell you want you need to do!
  Ford Focus ST2
ok i have checked the web and from want i have found the JVC is the same yellow and red.
whats happing is you have the switch DC to the permanent supple, and the permanent supple to the switched DC.
So when the key is in and yuou switch the car on you and then getting to 2 supples to the head unit with it needs to work, if you swap them over the permanent supple well be wiring in the the backup memery.
The reasion your losing it is as soon as you remove the key your removing the hold off voltage to the backup supple!!!!
Swap the 2 over and you should be fine (the main power connect normal have a join when you can swap them over to save cutting the wire!!!!
Hope this helps
Rob
  Impreza STI v5
cheers lads went on to the jvc web site and got the intallation guide yestarday got it working i thought that was what it was rob but didnt know what way they went, cheers
  Ford Focus ST2
not a problem glad i could help and i am glad its all working for you.
Can you send me a picture of it in the car as i would like to see what it looks like in the clio!
  Impreza STI v5
tryed to upload photos of it mate not going to let me, pm your Email address and will send you them if you want that is.
it,s an awsome headunit mate
