Headunit wont remember settings
Car  Clio 197 F1
Hi
I've recently fitted an Apline headunit and everytime I turn the engine off it looses its setting.
Ive tried changing the red and yellow wires but seems to be having the same problem.
Can anyone help?
Really? Thats about all it normally is? Depening upon how the wires are setup can you try different combinations of red and yellow wire connections? I.e are there more than two ways they can go? If not, just run a new constant live from the battery.
check the fuse box,you may find the fuse for the permanent live has popped as if its not saving at all either way then there will be a problem with the permanent
