If you get a torch, pop up the bonnet and flip up the panel where the jack is and crouch down and look along the channel you may be able to see the fan assembly and connector. You may be able to feel it with your hand and give it a wiggle. Dont do this with the fan switched on, dunno if its possible to trap your fingers but you dont wanna find out the hard way. Plus you dont wanna get any potential electric shock. Theres a big rheostat thing down there.
Best way to do it is to remover wiper cowling thing:
Flip the nut holders up on the end of the wiper, take off the nuts. Pull off wipers, you may have to turn them by hand to free them, dont worry the bolt part will stay put.
Look for the 3 ( i think its 3) torx screws, one either side and one in the middle, take them out and the cowling pulls off, the top edge along the window is clipped to the cars bulkhead, pull firmly but dont lose the clips. Careful with the rubber strip along bottom of window. Once off you should be able to see better.
Refitting is the reverse but make sure the rubber strip is seated correctly, you dont want loads of rain pouring down. I siliconed mine.
