Heater problem (not clio)
  clio 172 phase 2
My mrs corsa c for some reason has no hot air being blown? Anyone had this problem before ? Been told its heater matrix
Dr HMS Derv Destroyer
  MK1DTi/vivaro/corsa
dam it, if it was a corsa D i know the common fault with the heater as iv fixed this week.
could be the exact same thing tho.
heater resistor pack, they f**k up either down to water shorting them out or general life expectancy. common to either stop blowing or the heat isnt working.
you'll have to find the heater blower and have a look at the condition of the resistor pack. aswell as looking at the matrix for any obvious signs
  clio 172 phase 2
Cheers mate been looking on the corsa forum they say to try flush the heatermatrix out cus it gets blocked
  MK1DTi/vivaro/corsa
illiminate the easy jobs first mate. do a coolant flush to ' unblock ' the heater matrix ( if its blocked, you'll soon know when s**t comes out )
then move onto the other possibilities.
it'll be something daft is suspect
  clio 172 phase 2
Yea probally mate all the pipes are hot to touch except the matrix ones so im asuming its that
  Clio T 314hp c43 AMG
Corsa c's are terrible if your trying to get an air lock out, I always have to use my pressure tester, does the car overheat? If all is running fine engine side it will just be blocked or an air lock.
  clio 172 phase 2
Car runs fine mate doesnt overheat fan comes on normally . Il flush the system and see what happens
