Hello & Track or not.
  Clio 172 Sport
Hi guys.
Im Nathan and this is my first post.
I drive a clio sport 172 MK1. Not cup model.
My main question is whether this is a good track car or not?
Take into account i live in Gibraltar so tracks i go to our Jerez, Guadix, Estoril etc. I.E Very hot.
My mate who had the same car but MK2 blew up 3 engines and says its good for everday but not for track. I thought i would get a better opinion haha.
Please let me know what you think and what i should do to the car before taking it.
  WRX
Loads of us track them with very few problems in this colder climate. How did your mate's blow up?
Nothing wrong with the car in heat as far as I'm aware, could even fit a cooler running thermostat if it became an issue.
Decent brake pads and fluid are all you need to have fun in my opinion.
  Cup In bits
Those tracks would see looooong periods of time on the throttle, I would think that's part of the reason for engine failure. More suited to bigger engined/higher speed cars.
  Clio 182
My Clio spends all day up towards the rev limiter on track and (touch wood and cross fingers) its never had any problems and I've been on some hot track days..... yes it is occasionally hot it the UK ;)
  Clio 172 Sport
Thanks for info guys.
I asked him and it seems two engines blew due to he increased the rev limiter to about 9000rpm or more giv or take. The 3rd engine he said that it was standard and just died on the track. He then came to conclusion they were crap, hence why i thought i would ask people with more clio experience. Now taking into consideration of the heat...Yes i know it gets hot in uk aswell (H4RRY) haha but should i go for an external oil cooler or just go for it as it....Standard.
  Lionel Richie
well you cannot rev safely past 7800rpm and in a hot climate you have to run an oil cooler with a decent 10W50 or 60 oil, change the rod bolts to ARP and you'll be fine
Ph1 Tom
This ^^^^
There's no real point really taking it past where you make peak power anyway, I change around 7-7.2k to make the most of the torque band.
I'd look for a minimum of a 13 row oil cooler but if you can fit a bigger 16 row or maybe even 19 then it will help keep temps down. A thermostatic sandwich plate will stop it getting too cold when the weather is colder.
  Listerine & Poledo
A Clio would be lost or Estoril.
There'll be time to have a shave by the time you've made your way down the pit straight!
  Clio 172 Sport
I don't believe it. On the way to work the clio seemed to have had a heart attack. Not sure if anyone has experienced this before but all the electrics went crazy, i.e the dials went to and back up and the hazards lights went on. Basically every light on thwe dashboard went on. Then i parked it and turned it off. However i went to turn it back on to see if that might have sorted it and now it does not start. Any ideas ? Was thinking maybe alternator or the belt but never seen that happen to a car before.
  Clio 172 Sport
Hey guys by any chance are the mirros on a clio 197 the same as athe 172? Reason being as i need a set and the scrapyard closest to me has a pair. Your thoughts?
