HELP! -02 Clio 1.2 16v misfire. Coil, plugs etc replaced.
  -02 Clio 1.2 16v
Hello from finland! I have 156k km which has a bit rough idle and and misfiring. Car starts really well and it has no fault codes. It had p0130 which went off when i replaced precat lambda.
Here is the list of what i have done now:
-Clean DTC sensor
-Clean throttle body
-Precat lambda replaced (delphi)
-Spark plugs replaced (bosch)
-new coilpack (bremi)
-map sensor cleaned
-connectors cleaned
-timing checked (now putting new belt kit + waterpump
-grounding/earth tested with jump cable from gearbox to chassis
