CLIO 172,CLIO182
Really could do with your help guys....just changed my gearbox on my 2001, (PH2 172). The original box had the speedo drive in the box, i have now changed it for a later box with no speedo drive, not bothered about the speedo working as it's a trackday only car and i can use a GPS speedo. The problem is, its thrown the ABS light on.... does anyone know if the ABS unit needs a signal from the speedo to work....and if it does can the ABS unit pick up a signal from elsewhere or is it not related at all.........your advice is very much appreciated.
