Been to pirtek, g-tek and every other local tek looking for this bit but no joy.
Its for my oil pressure switch, it wont fit on the back of the block now because of my t-piece for the turbo feed so I need a 90 bend (may get away with a 45) so I can screw the pressure switch in
dad said, some of the parts they use are imported from the yanks ( cant remember the name for them ) but he did say, when he had his old boosted mk2 XR2, he used a company called www.burnettandhillman.co.uk/
Could you not manufacture your own mate out of some 15mm pipe, 13mm inner diameter? Just run a tap through it and then tap the other side. Depending on the pitch too I guess
Cheers jay, they're not too far away so could always pick it up. Will try them later.
Chapster, it's not something I fancy doing tbh. Finding pipe, then the right size tap then an adapter, it's likely to cost a lot more than this fitting... If I can find it lol
