Help finding a fitting
Been around the local pipe places with no joy so looking to find one online if anyone knows of any good places?
Its a basic 90 degree bend with a male m14 thread on one end and a female m14 thread on the other.
Been to pirtek, g-tek and every other local tek looking for this bit but no joy.
Its for my oil pressure switch, it wont fit on the back of the block now because of my t-piece for the turbo feed so I need a 90 bend (may get away with a 45) so I can screw the pressure switch in
Dr HMS Derv Destroyer
  MK1DCi/vivaro/REN’11
dad said, some of the parts they use are imported from the yanks ( cant remember the name for them ) but he did say, when he had his old boosted mk2 XR2, he used a company called www.burnettandhillman.co.uk/
Cheers jay, they're not too far away so could always pick it up. Will try them later.
Chapster, it's not something I fancy doing tbh. Finding pipe, then the right size tap then an adapter, it's likely to cost a lot more than this fitting... If I can find it lol
I use the Deeside branch, just make sure they understand fully what you want. I usually just take the old pipe in with me.
They can also do a pressure test on the hose for you if you need them to.
