Help Mk1 central locking problem!!
Car  95 Clio 1.4 RT
Hi all,
I've got a 95 Clio Champs Eylsees 1.4RT, had it for about 6 months now. The only issue I have with it is the central locking.
It doesn't work at all, either using the switch on the console or using the key (either remotely or direct into door). When I press the central switch you can hear the relay click and you do get a small movement on the lock mechanisms, but never anything more than a wobble.
Anyone got any ideas on a solution or came across this before?
Jay
Not too sure but this problem on MK2's will be the lock solenoid being knackered. Possibly that? Im sure someone else will know more then me :)
