Help!! Need some ideas please :)
Car  Mk3 Clio 200 cup
Hello all, new to forum.
I have a 200 cup and the engine makes a knocking sound. Its really odd, it only happens when the engine is warm, only on idle and the car drives and pulls perfectly fine. Its had a new oil pump, oil chain, cambelt, dephaser, rod bearings and bolts. Still makes the noise. Any ideas? Ive attached a video of the sound. TIA
  • IMG_2571.MOV
    20.4 MB
Did a renault specialist do the work above for you using all the correct locking tools etc when work was carried out?
To me that sounds very similar to the noise of a dephaser pulley that needs replacing
Yeah was all done with correct tooling. If it was dephaser pulley would it only appear on idle and when engine is warm?
Unfortunately my knowledge is rather limited and i cant say for sure, usually a dephaser pulley makes noise regardless but im also unsure if these are the same dephasers on the 200 cup.
