Help needed on dash light
Car  Arctic 182
Hi guys, driving home from work today and one of the lights on the dash came on. The one below the petrol light and above the oil light, i read in the manual its electrical?? Could anyone give me pointers as to what it could be and how to sort it out? Thanks Ricky. PS my clio is a diesel not sure if that helps
have a wiggle under the passenger seat, clios have poo wiring under there.
my cars lights are allways going on and that sorts it out.
its a yellow sort of coil and a box above the coil, the manual said either electrical, or heat something or other so im not 2 sure what it could be, any ideas would be helpful:)
I was thinking that ryan, on the diesel dont u usually wait 4 that light to go off to start the engine? so that the glow plugs are ready? maybe i should sort some plugs out!
have you tried the wires under the seat????????
mine went off after a fiddle!!!!!
The airbag light might but the electrical fault warning light won't! Indicates either glow plug issues or an electrical fault with the engine electrics/electronics.
The airbag light is on so i'll fiddle with the wire, im getting some glow plugs to see if the other light will go off thanks 4 your help!
