help needed
Car  clio 172
hi all,how do i take the key apart on my clio as it is not locking/unlocking my clio 172 it opend the car but wont lock it i think it just needs taking apart as it isnt clicking the mechanism in the key if anybody can help me with some advice it would be greatly apreciated
Does it lock/unlock okay using the button on the dash? If not it is pretty common and will 100% be water ingress in to the UCH which will have blown the PCB track and no doubt the relay to. The fix is a new UCH as the relays are soldered to the PCB.
Mick
hi matey yes it locks fine from the button on the dash
New key button required then, possibly a key itself i'm afraid. I've not got any of the buttons in stock atm i'm afraid so can't offer to fix it but its not a difficult job... normally around £20.
can i not take the kep apart and repair???if not where can i buy a key button from and does it have to be coded
It depends exactly how it has failed: Sometimes, the solder breaks so the button itself isn't making a connection and is an easy fix. Most times though the button simply wears out so it needs replacing and re-casing.
how do i take the key apart matey
There is an obvious point that you can slide a screw driver in to prise the casing apart. It may just need a new battery.
Proberbly the switch that's fallen away and a new one is an easy fix. To answer your question, NO, you can't simply replace the keys PCB as it is coded to the vehicle.
Mick
Mick
hi mick yep the switch has fallen away how do i fix it and whats the cost incured to do this??
